Trying to build a mini pc with built in battery and a tablet touch screen monitor
Ang Swee Chow
Commendable
Mar 25, 2016
Hi! I'm trying to build a mini pc that is ok as a work computer.
I want to battery power it and have a wireless tablet monitor so I can work on-the-go. Is it possible to do this with a reasonable budget of say.. $700 or is buying a 2-in-1 the best solution?
P.s. Can you please give suggestions on how this can be done even if you think a 2-in-1 is better?
Thank you!
1| It's possible if your wireless tablet monitor can accept WiDi technology by which you can get a Intel 7260 wireless card and can stream the video to your display.
2| For all intents and purposes it's a moot point going with what you're suggesting simply because you can buy a netbook that can accomplish the task at half the price point.
3| Might I ask what you mean by work? A lot of people consider doing work as a DJ :) You will also need to follow through this thread and post a followup with the necessary details to get a better answer from the community.
