Trying to build my first PC
edaschner
22
Never built my own PC and am trying to save some money by doing it myself. I think I've picked some pretty decent stuff but want to know if it will all actually fit together and also any tips for trying to put everything together for the first time or if something else might work better or cheaper compared to these. Thanks in advance.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811320002
Harddrive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822178380
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487028
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231550
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
Optical drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Thanks, I'll look into the harddive. Could you suggest any decent GPU that would stay under $175?
I'm planning to do a build when I get to Wichita, KS in August. I wanted to get a head start into finding what parts I wanted that go together and taking time to research them.
