I'm trying to connect to a wired internet connection AND a wireless network for local file-sharing and security cameras. Windows 10 does not auto connect to the WiFi when the Ethernet connection is present. Is there any way to force it to connect?
I'm not sure what you want but I feel like the best solution is to either us a Virtual Machine(VM) so that one OS is connected to ethernet while the other is on WiFi or maybe get a second computer.
No, one would be a internet connected network over Ethernet, and another would be a local network separated from the other network. It works but the WiFi connection doesn't reconnect on reboot or if the connection is lost for some reason.
SMARTZ921 :
I think you mean that you want to bridge the connections?
