Trying to find out if my dell power supply is standard or proprietary
denjtech
5
I am trying to figure out if my power supply in my xps 730 is standard or dell proprietary.
Model: H1000e - 01
p/n: HP-s1k03a001 lf
I have read the same number of posts in different forums telling me that it is proprietary and not proprietary.
Any help in this matter would be greatly appreciated.
I had a look and it was very close, I noticed there are two red lines in the in the first +5vdc on and two orange cables going into the second +3.3vdc on the side without the clamp.
Thank you again for the help.
Hi
I did a quick search for Dell documentation for XPS which said the PSU is rated at 1 KW
does it use a standard IEC connector on its power cable/socket in PSU ?
Some high power Dells use a larger connector for their power supplies
Have you checked with Dell for the cost of a genuine replacement against the cost of a good quality 1 KW PSU
In UK cost starts at about £100 but reliable brands £150 to £200 ( UK pounds)
regards
Mike Barnes
Hi,
It is a standard IEC connector.
The issue is kind of opposite, the power supply is good, I am putting in a new mother board, and do not want to pay for a new power supply on top if it if I can at all avoid it.
Thank you for your help
Forrest
Hi
You can get a power supply tester which checks the voltages on 20/24 pin motherboard connector, ATX 4/8 12V, PCIe 12V (graphics card connectors)
molex, floppy and SATA connectors which will give a good indication of compatibility.
also look for any non standard connectors not mentioned above.
UK examples of testers
http://www.maplin.co.uk/computing/pc-power-supplies-and-ups/power-supply-testers
regards
Mike Barnes
