Trying to finish my first water cooling system
buba333100
Hey guys, I'm a long time lurker, first time poster. As the thread subject says, I am trying to build my first liquid cooling system for my comp. I have spent a couple weeks doing research and figuring out what and where everything will go, so I am all set as far as knowing what to do, I just wanted to post my parts and see if I did something wrong there. I could have made a grave error somewhere and I would have no idea until it was too late. So here they are:
Rad
http://www.frozencpu.com/products/14274/ex-rad-306/Aquacomputer_Airplex_Modularity_System_360_Radiator_-_Copper_Fins_-_Dual_Circuit_33037.html?tl=g30c95s161#blank
Block
http://www.frozencpu.com/products/19628/ex-blc-1442/EK_Supremacy_Universal_CPU_Liquid_Cooling_Block_-_Clean_Plexi_EK-Supremacy_Clean_CSQ.html?tl=g57c603s1912#blank
Res
http://www.frozencpu.com/products/16933/ex-res-420/Bitspower_Water_Tank_Z-Multi_400_Inline_Reservoir_-_Clear_BP-WTZM400AC-CL.html?tl=g30c97s165#blank
Pump
http://koolance.com/pmp-500-pump-g-1-4-bsp
Shroud
http://www.frozencpu.com/products/12587/ex-rad-217/Phobya_120x120x20mm_Fan_Radiator_Shroud_-_Plexi.html?tl=g30c429s163#blank
I plan on running just distilled water and a kill coil in the loop so I tried my best not to mix metals at all, but I could have missed something, or if you recommend different parts try to keep that in mind.
Other than that do you guys have any preference on fans, tubing, barbs, and compression fittings?
Thanks again, I really do appreciate any help or tips you guys can give me.
