[SOLVED] Trying to flash bios and now I'm stuck, first time builder help pls
Dec 7, 2022
6
I have a MSI PROZ690 DDR4 motherboard, I'm trying to flash the bios before using a 13th gen cpu. I'm pretty sure I did all the steps right, the led on the motherboard blinked for a while and it just stayed on, it's been almost a day now and I'm not sure what to do. The manual says the led will be off when it's finished.
The only thing I realized I did that's different to what the manual says is I plugged in CPU_PWR1 and CPU_PWR2 instead of only CPU_PWR1, but surely that shouldn't be the problem right?
Dec 7, 2022
6
can you take a video how you do it from step one, to be sure?
upload to youtube or similar
maybe it worked correctly nonetheless, try the CPU with it
Yes I thought that might be the case so I installed the CPU, but somehow the RAM doesn't line up with either direction....
Here's a link to photos: View: https://imgur.com/a/0byfA27
I double-checked the motherboard is DDR4 and so is the RAM, I have no idea why it would not fit.
