trying to get a 3rd monitor going need help with graphic cards
fonzslapsblonds
4
i have a gtx 760 and im not trying to pay like 350 400 on another 1. was wonderering if i could sli with any other card. should i get a 970 or what?
fonzslapsblonds
4
should i just get a refurbed gtx 760 (reallllyyyyyyy want a new card) or 2 960s. Or can i hook my 760 with a 960. and how many watts to run both. will run them on this MSI X99S Gaming 7 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.0 ATX Intel Motherboard . Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3 140W BX80648I75820K Desktop Processor will be awesome
pauls3743
1,836
272
WOT
A really expensive high-end processor and motherboard and you're skimping on the graphics card???
You can only SLi same model NVidia graphics cards e.g. a pair of GTX960s, you cannot SLi different models within a range and certainly not when they are from different series.
I hope you don't have the Haswell-E stuff yet as I would suggest going for an z97 board with i5-4690K or i7-4790K and spend the saved money on a better graphics card like a GTX970 or a R9-290x.
fonzslapsblonds
4
so 1 gtx 970 is good enough for 3 monitors. i kind of really like that mo board and processor tho im not trying to cheap out on a gpu just wanted a second card to help out was wandering what my options were. and can maybe sli the 970 with a 980? thank you btw for the help dude
pauls3743
1,836
272
The GTX970 will only SLi with another GTX970, it will NOT SLi with a GTX980. A GTX 970 will drive 3 monitors but you might need adaptors as the 970 has mostly displayport ports and only has a single DVI and a single HDMI port.
Personally, I have 2 main systems. One with a Radeon HD R9 290 4GB, the other with a GTX Titan 6GB. They can both drive my desk setup which consists a 4k centre screen (displayport) and a pair of 1080p screens flanking it (1off DVI and 1off HDMI).
fonzslapsblonds
4
ok thanks. ya i have adapters already. i have 1 144hrtz monitor and 2 60 htz benq 1ms response. but stuck with shitty amd so im making the move now. and it sounds like im getting 2 gtx970s. and ya ill basically have a second rig. THANKS ALOT almost made a huge mistake. my friends like ya the 760 and 960 can do it pshh i
