Windows does not create the sound. The sound is created by hardware that is attached to your motherboard. Software in Windows controls the sound. If you can tell us what your motherboard is, it would be easier to find exactly what third party software your system uses. Or, if your computer was made by a manufacturer, Dell for example, give the Name and model #, and someone here may be able to find the correct software.
Without this information it is not possible to help you.
