[SOLVED] Trying to get one program to have larger fonts - stuck!
Tim F
28
Hi all,
I'm running DaVinci Resolve and the text is coming through really small on my monitor. I am on a 28 inch monitor at 2560x1440. Is there any way to change the font size (using Windows 10 scaling) for ONLY this app? All the advice on fixing scaling issues that I've found has not worked (other than changing this for all apps which I don't want).
Thanks, Tim
Have you tried Ease of Access?
"WIN" + "I" > Ease of Access > Display > Magnifier
You may be able to find a suitable configuration under either Display or Magnifier.
Afterwards, depending on a suitable configuration you may be able to create a macro of some sort to enable the larger text when DaVinci Resolve is opened.
