Hello. I am trying to mount a second Fractal silent fan 1400 to the front of my new fractal design define r5.
The problem I am having is.
You mount the fan from the front I imagine (as there is no instructions) Even though I'm usually pretty good with this type of thing.
But mounting from the front does not let you put the rubber screws in the case first.
So I pushed one through the fan itself (to try) and then tried to get the approx 1mm that sticks through the other-side of the fan through the tiny case hole that's level with it.
But having no access to the rubber thing (as its between the fan casing) and the fan is inserted into the case (from the front) No way was I going to be able to access, let alone pull the 1mm through.
The only other way was the tiny grub screws also included. Now these are Way to short to screw from the front through the whole depth of the fan. And I cannot screw them through just one plate of the fan casing as (again) it is inaccessibly, inserted as it is in the PC case.
And they are to fat to go through the tiny holes on the inside of the front of the Define r5 (that wouldn't let me access the rubber tips of the rubber screws) So The grub screws are also no use.
Now I do not know if these fans http://www.amazon.co.uk/Fractal-Design-Silent-Series-140mm/dp/B007XVLMZ6/ref=cm_cd_al_qh_dp_i
Are only meant for the bottom and top of the case.
But from all I read before buying This fan-- (I didn't pay 36 quid BTW, I paid about 10 pounds) --it did not say anywhere they could not be attached to the front. I want to put it on the front for maximum noise reduction.
I hope this makes sense.
Thanks for any assistance.
