I recently moved into an apartment and ordered Verizon Fios. My speeds are 150Mbps down and 65Mbps up. I installed a wireless AC router, but because of the size of the apartment and obstructions, my speeds diminish as I get further away from the router.
I have to keep the AC wireless router in the front bedroom, because of Verizon, and the location of their equipment and plugs. Sadly, it cannot be moved to the center of the apartment.
I recently discovered that the apartment is wired with Cat5e cable at every phone jack. However, there are no RJ45 jacks, just a standard phone jack. I can easily replace the jacks to have both phone and data ports though.
My confusion is this:
My Cat5e cable has 6 twisted pairs inside the cable itself, the colors are:
Blue solid and Blue/white striped
Orange solid and Orange/white striped
Green solid and Green/white striped
Brown solid and Brown/white striped
-----------------------------------------------(also....)
Grey solid and Grey/white striped
Red solid and Red/Blue striped
That gives me a total of 12 individual colored wires or 6 twisted pairs... However you look at it.
The Blue solid and blue/white striped are being used for the home phone lines. Sadly, I still have home phone service.
The remaining colors have been twisted and rubber-banded at the telephone patch panel. I do not have a data patch panel yet, but I will buy one.
The Verizon Router and my AC Wireless router are located right above the phone patch panel. So I can easily connect cables from the data patch panel to the router.
My question is this:
(1) If I want to use the current cat5e cable for both data and phone, which colors should be used for the data patch panel and wall jacks? (The blue and blue/white are currently used for phone)
(2) And should I replace the blue and blue/white twisted pair being used for the phone line, with another color, to free up the blue lines for data?
Things to consider:
The cat5e cable is solid cable, NOT stranded.
The cat5e cable is NOT daisy chained.
I only have 9 jacks, so a small 12 port data patch panel is suffice, even though only 3 jacks will be wired for Ethernet.
Things to consider:
