News TSMC tandem builds exotic new memory with radically lower latency and power consumption — MRAM-Based memory can also conduct its own compute operat...
SOT-MRAM is theoretically capable of latencies up to 10ns, which is certainly slower compared to SRAM (read and write latency of SRAM is typically in the range of 1-2ns), but is slightly faster than DRAM (DDR5 has latency around 14ms) and considerably faster than 3D TLC NAND (which has read latencies between 50 and 100 microseconds).
DRAM = 14 nanoseconds (not milliseconds). The rest look fine.
Reactions: bit_user
I wonder where that number is from. I think the best we've seen in PC benchmarks is somewhere in the realm of 70 ns.
The rest look fine.
Uh, not NAND.
Not according to this:
That's 11-15 microseconds from the time a CPU sends a read request to the SSD's controller, and when it receives back 4 kiB of data. So, the raw latency of 3D TLC NAND is definitely in the lower single digit numbers of microseconds, if that.
Reactions: TJ Hooker
"jointly developed co-developed a spin-orbit-torque magnetic random-access memory (SOT-MRAM) array chip, the result of a joint development"
So you're saying it was developed in cooperation with another company?
Seriously who wrote this? So from 4 years ago? A single CO developed there is no hyphen btw, would have been sufficient but this sounds like it was written by a 5th grader who doesn't understand what they are saying.
DRAM latencies used to go down to 6ns in the DDR3 days.
It's a problem they always have to fend off, it seems. And it will probably continue to get worse with further density increases and the introduction of 3D DRAM for consumers.
Reactions: bit_user
That article is a little sketchy. Their first suggestion is essentially what HBM does. However, HBM has slightly worse latency than normally-connected DRAM. Their second suggestion is to change the refresh architecture, but I'm very skeptical just how much real-world impact refreshes have on DRAM latency - I think it's tweaking at the margins, at best. I do appreciate that their final suggestion affixes a specific claim of 13% to 20% reduction, based on topology improvements.
Anyway, the article is from 2017 and therefore has limited relevance to DDR5.
Don't forget how DDR5 adds on-die ECC. That will add a couple nanoseconds, based on my rough estimates of the logic complexity.
LPDDR5 makes it even worse, based on how certain operations are multiplexed between the memory controller and DRAM.
I think having much closer coupling of processing & DRAM could be a game changer. Instead of having the CPU's memory controller talking to interface circuitry on the DRAM dies, you can blur the lines and have the memory controller accessing DRAM contents much more directly.
Reactions: usertests
