TT Ultra120 Extreme compatibility question + some
Skinman
6
Hey.
I'm building a new rig and i was wondering if you guys knew for sure any P35 boards it fits on?
Also, is there any other cases except the Antec P182 with exceptional cooling that it will fit inside?
- Skinman.
The ThermalRight Ultra120 X fits just fine on my Asus P5k Deluxe. I use a P180 case, which is practically identical to the P182 you mentioned, so I can't comment on the case. I can say that if you get a case any narrower than the 182/180 that it will be a tight squeeze. I was careful the first time I slid the side back on because it looked like it might hit, but all was well.
Thanks for the reply. I was thinking maybe going for a CoolerMaster CM Stacker 832. Heard a lot of good things about it.
- Skinman.
hint: if you use an ultra-120 make sure you add extra thermal grease and bend the the mounting brancket/back plate for extran tension!
bend the bracket slightly so its further from the mobo - on thicker mobo's this maynot be needed
