Tubes are super super hot on liquid cooling system
This sounds like a defective pump. If you guys are sure the CLC (closed loop cooler) is connected properly (and it sounds like it is), then I would suggest returning/exchanging this device.
AMD FX-8150 3.60ghz
He says he can only hear the fans and he said he is not sure if its water moving as it could be vibration. Like I said, super new to this so not sure what it would feel like. Would it be super obvious? And the air coming out of the fan is cool, if that helps you any.
idle according to thermal margin (I know those numbers arent the actual temp, i just trust thermal margin more than speedfan etc for accurate temp) in AMD Overdrive is 30-40c
under load its 26c thermal margin
All he hears is fans lol
He says its a 4 pin connection and it just says CPU fan. Hopefully that was the answer you were looking for. Sorry if we misunderstand.
Thank you so much everyone for the help! Yeah he will probably ask for a replacement then because he said the instructions were pretty straight forward and it doesnt seem like any water is going through after he really felt it and stuff. Hopefully that was the issue.
Thanks again guys :)
