Turbo V Basic Settings Help I7 920 P6T
natefostersr
260
13
Can anyone help give exact simple Turbo V settings for an:
AIR COOLED INTEL CORE I7 920
P6T Motherboard ? Please !
I only want to achive a safe reliable Overclock.
[No BIOS options / only Turbo V settings please; listed below]
The only settings I can use are listed here. {Turbo V Standard}
* Basic Settings *
BCLK Frequency - ? ---(currently at 134 - 166 mhz)
CPU Voltage - ? ---(currently at 1.22500v)
DRAM Bus Voltage - ? ---(currently at 1.50v)
QPI/DRAM Core Volt - ? ---(currently at 1.20000v)
* Advanced Mode * {I can use this if necessary}
-CPU/CHIP VOLTAGE-
CPU PLL
ICH PCIE
IOHPCIE
ICH
IOH
-DRAM REFERANCE VOLTAGE-
CHA Data
CHB Data
CHC Data
CHA Ctrl
CHB Ctrl
CHC Ctrl
Thanks - Cheers
natefostersr
260
13
Well so far I've been able to set the ;
BCLK - Up to 159 then crash at 160
CPU voltage - I can not more it up at all or instant crash
DRAM Bus Voltage i have at 1.56
Qpi/Dram Core Volt is at 1.25
That has me at about 3.1 GHZ (3800mb transpher per sec; I believe its a 700mb increase) via mycooltools.com
natefostersr
260
13
Ok well in case anyone is ever interested. My 2nd day
Installed SPEEDFAN CPUZ and 3DMARK
Changed BIOS BLCK to 169 DRAM is at 1355
All voltages are on AUTO
3DMark scores-
A bit over 2000 for CPU
1300 ish for Graphics
Seems stable temps were good through the test.
I used ATI overdrive autotune for my 5850 processor is at like 3.36GHZ
Seems like a good solid 1400 dollar build to me.
Im a total novice
natefostersr
260
13
Turbo V ---------almost burned my mobo. It automatically raised the CPU voltage to 1.6
I disabled it completely might start a new thread about how I got my bios all in the blue 3.67 ghz fully stable temps under 70 all day. Seemed pretty easy (day 4)
ctguy1955
170
5
I have the same setup. Im a noob and almost was not going to mess with OCing, but I always buy asus MB and why, if your not going to OC? I was under the impression that if you were going to mess with OCing that you would turn off the Turbo Mode overdrive thing, and just do an overclock???? I only went up to 3.0 and stopped, but I have read many go to 3.6 with no problems.
I spent around 3K total on my system with everything. Two one meg 9800gt sli cards are ok, but I guess I could have done better.
CPU: Core i7 CPU 920 @ 2.67GHz
Speed : 3.0 GHz
Motherboard: ASUS P6T DELUXE V2
Memory: 12 gigs of Corsair CM3X2G1600C9 2GB DIMM DDR3 PC3-12800U DDR3-1600
Video Cards: 2 NVIDIA GeForce 9800 GT (2x 112 SM4.0 1.4GHz, 2x 1GB DDR3 2x900MHz, PCIe 2.00 x16)
Hard drives: WDC WD740ADFD-00NLR5 (74.4GB, SATA150, 3.5", 10000rpm, NCQ, 16MB Cache) : 69GB
WDC WD7500AADS-00L5B1 (750.2GB, SATA300, 3.5", NCQ, 32MB Cache) : 699GB
dvd:HL-DT-ST DVD-RAM GH20LP20 (ATA66, DVD+-RW, CD-RW, 2MB Cache)
Optiarc DVD RW AD-7170A (ATA66, DVD+-RW, CD-RW, 2MB Cache)
Case: Antec nine hundred two
natefostersr
260
13
I disabled Turbo and Hyper threading. (keeps Temps way Down)
Took Turbo V off the Startup list
Voltages in the blue run 3.8 GHz ive been up to 4.1 stable good temps with Air cooling
natefostersr
260
13
Mobo- ASUS P6T SE
Processor- Core I7 920 - Overclocked to 3.8
RAM- 6 GB Kingston Hyper X 1600 (running at about 1555)
Video Card- XFX HD 5850 - Overclocked (GPU 950 MHz)- (Memory 1150MHz)
Hard Drive- Kingston SSD 64
PSU- ATX 700w
3D Mark- P18685 (GPU-17209) (CPU25160)
Similar threads
