K Keeno99 Distinguished May 24, 2014 237 0 18,710 Jun 25, 2015 #1 My case isn't here yet and I want to start downloading games and such so I'm trying to set up an out of case build, I just don't know how to turn on my computer. Thanks in advance 😀
Solution CompGee Jun 25, 2015 Using a flat-head screwdriver, short the 2 pins connecting the power switch FOR A BRIEF MOMENT!
CompGee Distinguished Jan 1, 2014 1,646 2 20,415 Jun 25, 2015 Solution #2 Using a flat-head screwdriver, short the 2 pins connecting the power switch FOR A BRIEF MOMENT! Upvote 0 Downvote Solution
chadbry Distinguished Jan 28, 2012 206 0 18,710 Jun 25, 2015 #3 you can jump the front panel pins to start it, but i would just wait until you get a case. you have too much to loose screwing around with it Upvote 0 Downvote
K Keeno99 Distinguished May 24, 2014 237 0 18,710 Jun 25, 2015 #4 CompGee : Using a flat-head screwdriver, short the 2 pins connecting the power switch FOR A BRIEF MOMENT! I know, but I don't know where those pins are D: Upvote -1 Downvote
Vahe Bro A Reputable Jun 2, 2015 739 0 5,160 Jun 25, 2015 #5 here is a Video https://www.youtube.com/watch?v=G4FOBL1c3pA Upvote 0 Downvote
K Keeno99 Distinguished May 24, 2014 237 0 18,710 Jun 25, 2015 #6 Vahe Bro A : here is a Video https://www.youtube.com/watch?v=G4FOBL1c3pA I cannot find these two pins on my mobo Upvote 0 Downvote
Vahe Bro A Reputable Jun 2, 2015 739 0 5,160 Jun 25, 2015 #7 can you post a link of your motherboard? and i will tell you where it is Upvote 0 Downvote
