I just finished my first build, and have run into a problem.
Before I put everything into my case, I did an external build to test everything, everything worked, I even installed OS.
When I put everything into the case, which I finished a few minutes ago, I pressed the PSU button.
I didn't press the power button, yet everything turned on (fans spinning, etc.)
ANother strange thing is that the monitor wasn't picking up the signal from the video card.
Switching the psu on/off turned on/off the parts.
What could be the problem?
I even tried pulling out the front panel power plug and stuff, and the psu still turns on everything.
The psu shouldn't control the on/off, the motherboard power should...
