Turntable with built-in phono and TV to powered speakers that don’t have a remote, help!
julien.denoyer
Hi guys, I need help figuring out what I need to connect Denon dp-300f turntable (includes a built-in phono equalizer), and a TV to a pair of Pioneer SDJ50X powered/active speakers. I can connect the turntable to speakers currently but also want to hook up the TV to these same speakers while also having a way to control volume remotely as these speakers unfortunately only have individual volume buttons on the back. I’m thinking I need a receiver of some sort but am just not sure what to get for a reasonable price.
Thanks in advance!
Julien
You don't need a receiver.
What you need is an input selector with remote volume control. You don't actually need an active preamp since you don't need any additional gain or a phono stage.
https://www.amazon.com/Nobsound-Selector-Pre-Amplifier-Adjustable-Controller/dp/B01M18QM62/ref=sr_1_2?ie=UTF8&qid=1515695490&sr=8-2&keywords=passive+audio+preamp
but this doesn't have remote control of the volume.
Might be cheaper to get a separate input selector and remote volume control.
https://www.amazon.com/MCM-CUSTOM-50-8394-CONTROL-IR/dp/B01CX82KH2
If you like building stuff you can get the parts and make one yourself.
Try
www.parts-express.com
or...
Look at "integrated amps". A "receiver" generally is an integrated amp with a tuner added. If you want a tuner...look at receivers. ...but both of these have power outputs to speakers and your speakers are already powered...so you can get away with a preamplifier instead of an integrated amp if you don't want to power speakers.
Just make sure that if your built in phono equalizer doesn't have a phono pre amp, make sure that whatever you buy does have one....or your going to have to buy one separate.
Also, not sure if your
Try
or
https://www.ebay.com/itm/LITE-MV04-Motorized-Remote-Volume-Control-Input-Selector-kit/222153545847?hash=item33b9621877:g:KWgAAOSwkNZUkX56
