[SOLVED] TV Antenna to Wifi Converter
Nov 28, 2018
I have a very high-gain TV antenna. I would like to convert the antenna signal to a WiFi signal for a remote TV, not in the same room as the 75 ohm coax from the antenna. What converter can I get that will perform that task? Also I need a WiFi to 75 ohm converter for the remote TV.
You need a device similar to this one - a TV tuner with built-in transcoder, and special app on the other end. Unfortunately, this is not going to work with standard TV.
There are no standard "wireless ANtenae converters" available. Your best bet is finding a way to route quality antennae cable to your TV.
