TV & Monitor switching, resolution issue
Mickeyd_10
17
Hi guys. I have a monitor (1900x1200) and TV (1900x1080) hooked up to my Windows 7 PC via hdmi cables. Is there a way to switch my main display over to my TV so I can play games/watch videos on my TV instead of my monitor? Currently I have it set to to extend by default, then when I turn on my TV I press Windows + P to switch over my TV as my main display (then switch back to extended when I'm done).
However when I do this, it seems to still try to display 1900x1200 on the TV and as a result it is missing some lines from the top and bottom of the screens (e.g. the taskbar is halved in height and if i full screen youtube the playback bar is missing). Is there a way to fix this resolution issue, or a is there better way to switch displays (eg. third party app)? Could it be related to upscaling? I have a radeon 5870 running the latest drivers, if that helps. I don't need to have both screens working at the same time as they are quite far apart so its not really possible to use both at the same time. Thanks!
Hello... what happens when you run in "clone" mode?... a monitor is a passive device, thus Windows doen't care if my TV or Monitor is off or on... But i'm running the same resolution on both... and dont have to ever switch any thing... the resolutions are preset in my Windows device settings and Nvidia control panels for the monitors and Video output settings to 1080p.
You might have to run Windows at the resolution of 1080P, the maximum setting of your TV set... for simple ON/OFF operation as you want.
The problem with having clone mode / same resolution is that I get black borders on my monitor then 🙁
blade, the windows key + p shortcut seems to control this. It works but my TV doesnt scale properly. However I found you can adjust the overscan in the CCC control panel, which seems to fix my problem.
Now I've got another problem where I get glitches when I scroll. It looks like its related to having AMD Overdrive enabled.
Right. Ok. I had a 5870 for a while (it ended up dying on me) but you have to edit your CCC profile so that the want_0 (idle) and want_1 (2D) clock speeds are higher.
The easiest way to do it is to go to CCC and create a custom proflie over overdrive settings.
Once you have the profile, save it, and go back to default. You can only edit it when it is not in use.
Now go to C:\Users\*your user name*\AppData\Local\ATI\ACE\Profiles
Open the XML file with a text editor and change the Want_0 and Want_1 values for CoreClockTarget_0, MemoryClockTarget_0, and CoreVoltageTarget_0.
You can set them to the same values as Want_2 and your card won't go to power saving mode
Cheers, thanks for that. I noticed it only happens when its in extended mode - since I only will be having one of the monitor or tv enabled at any one time this isn't really an issue but ill look into that profile stuff anyway.
Just in case anybody else has the same problem, there's also a better alternative to using Win + P. Basically using Windows + P will need your primary monitor on so you can see the popup and tab through it. Instead, you can select each desktop on its own via windows display dialog and create a preset for each one in CCC and assign it a hotkey. Now I just have to press Ctrl+Shift+1 to output to my monitor and Ctrl+Shift+2 for my TV.
I have another problem now where if I use the HDMI/DVI port on my Samsung TV the image is sharp and there's no need to configure overscan even, but there are "dancing" red pixels on screen (I am using a HDMI->HDMI cable). If I use a port labelled as just HDMI, there's no red pixels but the image is overly sharp and text isn't as clear (also need to configure the overscan to get it to display within the bounds of the TV screen). Arrgh! Thought this would be easy...
Use the configuration that doesn't give you red pixels.
Then go to the start menu and type "calibrate" and click calibrate display color.
This will walk you through a setup for your display.
I changed the source of my TV to 'PC', enabled Screen Fit instead of 16:9 and reduced the sharpness levels (I think hooking it up the DVI port enables these changes automatically). All working fine now, with clear text and no artifacts, thanks for all the help!
One last thing - is there a way i can increase the font size on my TV and not my monitor? Even though the text is fairly sharp close up, when Im sitting far back its quite small. From having a quick look around it looks like I have to change it manually each time I change monitors?
I believe that is the case. Unfortunately as it is a windows setting, not a display setting.
If it is possible I don't know how to do it.
Glad to help with what I did.
If you have what you need, please close the thread by selecting a best answer.
Thanks!
