TV out help?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
ola group,
I'm putting together a new system and looking at nVidia cards. I'm on a
budget (-1500) and don't want to buy a monitor as I have access to a 60"
hitachi rear projector tv (4 years old, not hd) My question is... does
anyone have experience with the dvi/tv out on nVidia cards under $300? I've
read here and there that resolution can be poor for text, etc. w/tv out. Is
a scan converter the answer? Can anyone help me here? Suggest another ng if
not? I plead my ignorance.
Any help would be greatly appreciated.
Thanks
lojo
(email void)
On Sat, 10 Jul 2004 04:43:42 GMT, "lojo"
<lojo@stlink.net> wrote:
I have GeForce2 MX 400 64MB card , 17" mon & 27" flat
TV with desktop extended across both.
1- Resolution on TV is fixed @ 800x600 (~40pix/inch).
Text looks fine but to read it from 12' from TV I had
to tweak every setting in Appearances tab. Same with
IE6. All had to be so big that most pages need
horizontal scrolling & text sometimes runs together in
IE & nobody in 2 yrs could fix that. Also text on pics
& in Flash(ie. RR control panel) is very small & cant
be enlarged.
2-Must be 40 tabs on driver so be prepared to invest
some time understanding it. nVidea docs were sparse &
confusing at best in original v30 of driver. Driver
updates r frequent (v54 now) & v30 didnt work very
well. Both driver & docs improve greatly over time.
3- I gave-up on TS from nVidia- they never reply to my
emails.
4- Think I paid $65, retail was $110. I use 30% of its
capabilities which r amazing. I am not a gamer.
5-So far TV is useless for graphics. Getting gamma &
colors to match monitor is a nightmare. I use pic
editing apps (incl soft-proofing) on monitor ONLY.
6-I have physical disabilities that r helped by being
able to use PC from either my desk or my sofa so
all-in-all the benefits >>> drawbacks.
HTH-Larry
|ola group,
|Thanks
|lojo
|(email void)
Any advise is my attempt to contribute more than I have received but I can only assure you that it works on my PC. GOOD LUCK.
> a budget (-1500) and don't want to buy a monitor as I have access to a
> 60" hitachi rear projector tv (4 years old, not hd) My question is...
> does anyone have experience with the dvi/tv out on nVidia cards under
> $300? I've read here and there that resolution can be poor for text,
> etc. w/tv out. Is a scan converter the answer? Can anyone help me
Text from tv out is generally poor. However, if your projector will accept
that signal from the DVI output, then that's not considered TV out and if
it accepts a decent resolution signal, you should be okay.
Thanks Larry,
Your experience seems to have confirmed my worries,
I had hoped that the bigger-better-faster-more cards would
make a difference but I'm gathering from this that it is the tv
that is the limiting factor.
I'll be doing some gaming, so will want as full immersion as possible
in the experience, but mostly would be using a large display
(might go to lcd projector) for movies and viewing my
work. (composite 3d/dv/artified real-life 'animations' and music videos)
Thanks a million for your input. It was valuable to me.
lojo
"Larry(LJL269)" <NO@EMAIL.COM> wrote in message
news:81m1f0ph14jsi5jsvm0755920eeas0qgi2@4ax.com...
> be enlarged.
> emails.
> HTH-Larry
> |ola group,
I've
Is
if
> |Thanks
> |lojo
> |(email void)
"tq96" <tq96@tq96.tq96> wrote in message
news:Xns95237CAA6F0C8tq96@216.40.30.66...
accept
Thank you, I'll look into that.
lojo
"lojo" <lojo@stlink.net> wrote in message
news:xmfIc.478$NU6.80@news02.roc.ny...
> accept
if
> lojo
Projection TV or any TV will be your limiting factor. Reason is due to TV
resolution. You can feed it DVI / Fiber Optic or anything direct will do no
good.
Simply you can not force a pinto car with high octane or jet fuel and expect
to run fast as a sport car [general speaking].
CapFusion,...
Thanks... I'm coming to the conclusion that I should just keep one of my old
monitors and keep saving $ for lcd projector for the big stuff. I want it, I
need it... big sound, big screen, full immersion.
lojo
"CapFusion" <CapeFussion...@hotmail.., com> wrote in message
news:6r2dnV2yLaGxbW_dRVn-jA@megapath.net...
no
> good.
expect
> CapFusion,...
On Sun, 11 Jul 2004 13:41:01 GMT, "lojo"
|in the experience
1/2 of demos (4 racing, submarines, choppers,aircraft)
I try wont install or run on TV which is 1 reason I
tried TV as monitor. Could % of faulty demos be that
high?
BTW was looking at monitors & u can get reconditioned
Trinitron 19" Flat 4 $150 total.
GL- Larry
news:c0q6f0d1nsnni8pjl5mm0u6cgvua56v5l1@4ax.com...
> |in the experience
> high?
Demos faulty? I do not know if demos is faulty or other thing that is / are
contribute to it.
TV as a monitor? The only time I want my TV to become as monitor if I want
to watch movies / presantation and such but not as primary to replace my PC
monitor. I can not afford good TV monitor to have a good acceptable viewing.
CapFusion,...
> old monitors and keep saving $ for lcd projector for the big stuff. I want
> it, I need it... big sound, big screen, full immersion.
Once you've experienced a data-grade front projector you won't want to go
back. And they get better every year. Only downside is that $500 light
bulb.
> lojo
> no
>> good.
> expect
>> CapFusion,...
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
"J. Clarke" <jclarke@nospam.invalid> wrote in message
news:cd14fc0jkl@news3.newsguy.com...
want
> bulb.
I guess that's 25 cents an hour if it burns for 2000, not bad!
What would you consider data-grade? Could you give me a couple of examples
to study... price range etc. Just a brand and model would be helpful, I'll
sleuth 'em. I had 1500 budgeted (30 month plan @+/-$300 per month for
complete 'electronic arts studio') Am I in the ballpark?
Thanks Larry.
> |in the experience
> high?
> GL- Larry
> TV resolution. You can feed it DVI / Fiber Optic or anything direct
> will do no good.
An HDTV can output 1280x720 or 1920x1080 (interlaced). With a DVI signal
feeding it, the picture ought to look fantastic.
news:Xns9527F062D3E63tq96@216.40.30.67...
I am looking for a HDTV that have 1920x1080. Do you know any?
CapFusion,...
news:dqCdnVQS9dKcnWXdRVn-iQ@megapath.net...
signal
> CapFusion,...
Most of them do Cap. Maybe the problem you are seeing is a video card that
will properly output 1080i to an HDTV.
"Biz" <biznospam@notatt.net> wrote in message
news:zbUJc.265125$Gx4.150257@bgtnsc04-news.ops.worldnet.att.net...
that
You are right..... I was not paying attention to the detail of the item or
looking at the right place. This is one of the TV that do have the res -
http://www.rca.com/documents/1614682B_702750_25.pdf
CapFusion,...
