TV won't connect to wifi
Angelica_5
Commendable
Aug 14, 2016
I have a toshiba tv model number 42tl515 software version 2.2.5 (3d): jun 05 2013- 14:52 . It used to connect to the Internet but now it doesn't. It does not even register any networks when I try to search for networks to connect on. I get an error message saying no Ap'so found.All other devices are connecting just fine to the wifi. We are using anow apple airport extreme wifi router. I have reset the TV and still nothing.
Not sure that I understand correctly. Are you saying that you cannot see/find the wireless setup menu...
Do you have the User Manual?
If not, here:
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su3020966/TL515U_EN_OM_Rev1.06_1104.pdf
When you did the reset the TV probably went back to its' factory default settings and you will need to enter the menus and re-enter the wireless configuration data for your network: e.g., SSID, encryption, password, etc..
Wireless setup is on Page 63.
If not, here:
