I have 2 Samsung HD204UI 2TB dives together in an external enclosure that have both died. I've taken them out and tried to connect them to the computer separately, and neither will spin up when the power is plugged in. So I'm assuming there's been a power issue with the PCB, and have been doing some reading on the TVS diodes.
I've found the diodes on the PCB according to this picture
http://www.users.on.net/~fzabkar/HDD/HD204UI_TVS.jpg
I've tested both diodes using a multimeter. When I set the multimeter to 200ohms, on the 12V diode it reads 1.1ohms. The 5V diode needs the multimeter to be on 2000ohms to get a reading, and that reading is 1310ohms.
I was under the impression that if the diodes had blown they would read close to 0hms. Is the 1.1ohm reading on the 12V diode suggesting that diode is blown? If so, do I just remove it from the board?
I have some really important data on the drives and would love to save it before spending alot of money. Any help is appreciated!
