1 10Death Commendable Dec 10, 2016 1 0 1,510 Dec 10, 2016 #1 Can two 6 pin plus 2 pin connector connect and work for a gpu with only one 6 pin connector? Please Help.
Solution Geekwad Dec 10, 2016 Yes, it is a 6+2pin connector: http://www.realhardtechx.com/index_archivos/Page362.htm Able to be used in 6 or 8 pin applications.
khashayar2000 Respectable Jun 24, 2016 603 0 2,660 Dec 10, 2016 #2 Yep It Will Work The Problem Made When U Have A 8 pin and 6 pin cpu For u The Situation Is up side down or sth like this so no problem it will work best regards khd Upvote 0 Downvote
Geekwad Admirable Sep 25, 2015 2,368 1 6,960 Dec 10, 2016 Solution #3 Yes, it is a 6+2pin connector: http://www.realhardtechx.com/index_archivos/Page362.htm Able to be used in 6 or 8 pin applications. Upvote 0 Downvote Solution
