With my new build, the orientation of my Coolermaster 212 EVO cpu cooler will drastically affect the airflow in my case. Each orientation seems like it has a negative and that is causing me to be unsure as two which I should go with.
Vertical orientation:
With this mount, the cpu cooler blows cooler air over the fins but I am afraid that the 200mm fan up top will cause some turbulence (green arrows show where I think it will occur). Note the blue circle with the arrow in it represents the side intake fan.
Horizontal orientation:
With this mount, there will be no turbulence up top, but the cooler fans will bring warmer air over the cooler's fins because the air it pulls through will come from the area around the graphics card.
Which mounting option do you all think will be best for keeping everything cool?
