Greetings;
Im planning to buy few fans to cool my system down. I went to nearby shop and it was having discounts on Corsair Fans. I searched on the internet and it seemed like corsair fans has good reputation. I found two dual packs with different names product name BUT on the internet they have almost same specification and the shop is offering same price. links below:
Air Series SP120 LED Green High Static Pressure 120mm Fan Twin Pack
http://www.corsair.com/en-us/air-series-sp120-led-green-high-static-pressure-120mm-fan-twin-pack
Air Series AF120 Performance Edition High Airflow 120mm Fan Twin Pack
http://www.corsair.com/en-us/air-series-af120-performance-edition-high-airflow-120mm-fan-twin-pack
I understand high static pressure is good for radiators or if you have filters and obstacles in your case mounting.
while airflow would provide greater volume of air flow.
considering the two fans have different titles, the specs almost the same in terms of static pressure and airflow.
the problem is I dont like the green led, I was thinking of buying 2x dual packs of airflow version and use one pack of radiator (Coolermaster evo 212) .
My case corsair A200 if u just wondering.
