So Two drops of olive oil (which i had use to fry stuff) fell on my laptop while i was eating (I know, I'm stupid). I almost immediately cleaned them, and the laptop seems to be running fine.
Initially i kept using it, but after a while i realized i started obsessing about it so i left overnight turned it upside down (for about 12 hours) to see if anything came out. No oil came out of it (i had a couple of napkins underneath to check)
Everything seems to be working fine, i'm using it now, and the keys aren't sticky or anything, but i'm still obsessing about it.
Am I good? Or should I take any other precaution to avoid an eventual disaster as some hypotetical residual oil seeps in the motherboard?
The main thing that scares me is that oil, unlike water doesn't evaporate...
P.S My laptop is a hp pavilion 17 (https://i2.wp.com/laptopmedia.com/wp-content/uploads/2016/07/IMG_2932.jpg) and while i tried removing the keys to clean it, it took me about one hour to put the first key i removed back, given that the keys work with a very weird plastic mechanicsm, so sadly taking all the keys off to clean more thoroughly isn't really an option
P.S. Please answer to this if you have any idea about it, this stuff is making me increasingly anxious and any take on it might help me calm down
