I have two Sapphire Tri-x OC R9 290x's in my PC. Identical cards both running on x16 slots. However the second slot card is only showing a 32bit bus width in GPU-Z while the main card shows 512bit. The cards are both recognized as existing by both GPU-Z and Catalyst, but the second card does not display any diagnostics in Catalyst.
Any idea why the second card is not running properly or being restricted?
Build:
Amd FX 8350 4ghz
32Gb GSkill 1333mhz
Gigabyte 990FXA-UD3
Rosewill 1000w
2x Sapphire Tri-x OC R9 290x
Build:
Amd FX 8350 4ghz
32Gb GSkill 1333mhz
Gigabyte 990FXA-UD3
Rosewill 1000w
