So I was planning on getting another monitor for my PC and what I was going to do was plug is one monitor/TV with an HDMI cable then I was going to plug in a DVI-D cable in the same gpu and have a DVI-D-HDMI cable to plug in the second monitor with that and I was just wondering if this would work as two monitors.
Thank you.
PS I only have one GPU if that helps/ if you didn't get that from my description
Thank you.
