Did a little research and the problems seem common, but mine are slightly different.
Problems might be related.
First problem is my computer wont shut down. When I hit shutdown, it says shutting down and then continues to turn off the screen. But all the lights and fans remain on. Only fix is to hold down the power button.
Second problem is my computer wont wake up from sleep. After going to sleep the power light flashes. But then regardless of what i do it just remains asleep, no fans either, just flashing power light. Again the only fix is to hold down the power button.
Am i missing a simple setting or something? I was wondering if its an SSD related problem or such?
People have similar problems but when they hit power button they say the computer wakes up, but the monitor doesn't. Which is not my case.
Edit: I found some people found powercfg /energy helpful, though i dono what im looking for lol.
5 errors
16 warnings
13 informational
The report just says page can not be displayed. Though notepad shows the works, but with a lot of script code added in :s. If it would help i can filter it out.
[strike]Two [/strike] Three lines read
USB Suspend:USB Device not Entering Suspend
The USB device did not enter the Suspend state. Processor power management may be prevented if a USB device does not enter the Suspend state when not in use.
CPU Utilization😛rocessor utilization is high
The average processor utilization during the trace was high. The system will consume less power when the average processor utilization is very low. Review processor utilization for individual processes to determine which applications and services contribute the most to total processor utilizationPlatform Power Management Capabilities😛CI Express Active-State Power Management
PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
