Hello Peoples,
I need to borrow some brain cells. Here is the situation:
- Downstairs i have a router and a switch
- In my attic I have 2 security camera's that are connected to a POE switch
It would have been too costly to run a cable from the switch to the router in the basement due to the layout of the floor - so I decided to try and use the powerlines in the house to run down to the basement. That all worked fine for a bit - however I've started to get a lot of dropped packets and I've determined through my troubleshooting it has to do with the power lines carrying the network traffic (or the devices i'm using to connect to the powerlines).
Instead of taking a cable and running it through the walls which would be pretty expensive - is there a way i can connect the two switches together using wifi?
