Topic: "Bridge LAN interfaces into a single network" setting on Ubiquity EdgeRouters (I have the Lite version)
I see mixed guidance online. Most video posts on setting up the router suggest to use it. On forum posts I have read, it seems you shouldn't.
What are the advantages and disadvantages of bridging the two LAN ports? In my case, I will be using a switch, so I only technically need one port connected. Is there a performance boost in network speed if I use both LAN ports connected to the switch? Or will the opposite happen? Or does this setting just open up another port to put a wire into, like a switch with no other benefit?
I mainly stream movies, listen to music over my network system, transfer files over the network, play games, etc. It is for a home network.
The setting is being checked off in this video below at the 9:15 minute mark (video should be cued).
