G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hello,
I'm a Videostudio 7 (incl. SP 7.01 ) Newbie and just did some testing before
I will receive my DigiCam hopefully in the next days. The problems I have
are the following:
1.) Tried to load a *mpg file (not self recorded, but a trailer from the
internet) then an error msg. occured "File does not contain any video data"
but this file runs properly with Windows Media Player. And also I can load
the VS7 - Sample *mpg file. Is there a difference between *mpg files/fomats?
2.) Tried to load an *avi file then the whole programm crashed with "Windows
General Protection Error" ? Is is possible to load *avi files, are there
also differences between files/formats? What I'm doing wrong?
3.) Are there any Quick References / Startup Tips: a) how to create the
first video on CD b) how to get analog VHS files to CD? Because I try to
prevent to go through 150 PDF pages of the manual.
Thanks for any help and best regards,
Sascha
Hello,
are the following:
Sascha
