Ultra 120 strange and wonderful temp drop!!
heroofspirits
171
hello all
i have a ultra 120 by thermal right. to begin with, it was a bitch, was never cooling the cpu was like never having a heat sink on it. :fou:
this morning, i decided to replace the heat sink, clean it up then replace it. once i had re clocked my cpu, i entered windows and booted it up prime and core temp.
i was amassed by this, my temps on the cpu had dropped by 30 degrees Celsius!!!! all i did was clean the bottom of the sink with some paper towel!! though i did notice a glue like substance also come of with the thermal paste. possibly left over from the sticker that was on it to protect it whilst in its box. :heink:
has this happened to any other 120 owners, would like to know. please if u do post leave your max and min temps and what clockage u have it set at. :ouch:
My max and min temps are 35 to 73 approximate. 😀
No. Mine had a plastic cap protecting the bottom. And mine had a pretty sloppy machine job on the bottom, so I hand lapped it and ground it down to the bare copper. I combined it with a Scythe S-Flex SFF-21F fan. Q6600 OC'd to 3.6 GHz., temps are 61 C to 66 C.
