Ultra wide plus standard dual monitor setup?
f847
67
This is doable right?
For a AMD RX480 to run two monitors at different resolution at the same time.
Sorry bit hard to search as most results are ultrawide vs standard instead.
Thanks in advance
Are you wanting to dsiplay on 2 monitors or game on them?
For gaming cant really game on 2 different resolutions
To display of course the 480 can display on 2 monitors, a $30 graphics card can display on 2 monitors
Now if your vertical resolution is different accross the monitors then you will not have smooth scailing of windows and text as it goes from screen to screen.
Yeah I thought it should have no problem. Just want to be confirmed by someone else in case.
Only to display. Will game on the standard only. Will also keep in mind I get both for 1080 p heigh.
Thanks
