Ultrasharp 1900 monitor and DVI
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
My mate received his new Dell 8300 computer today (nVidia card) along with
the above monitor. It runs fine with the analogue VGA cable but when we
tried the DVI cable we just got a black screen with a VGA "screensaver" and
an orange power button light indicator. It was then difficult to get VGA
working again.
I assume this is the Power Save Mode problem. How reliable is the Dell fix?
Brian
It's probably not the DVI Standby issue. When connected to the DVI cable,
the monitor has to be switched to DVI mode by toggling the input switch. See
here:
http://docs.us.dell.com/docs/monitors/1901FP/en/controls.htm
"Brian K" <iibntgyea4_ remove_this_@hotmail.com> wrote in message
news:z20tc.11968$L.6802@news-server.bigpond.net.au...
and
> working again.
fix?
> Brian
Did you switch the monitor to DVI mode (button on front of monitor)?
and
> working again.
fix?
> Brian
Thanks guys. I didn't know about this switch and there were no instructions.
I'll let you know in a day or two when I see the computer again.
Brian
"lynnr" <nospam@nospam.net> wrote in message
news:2hjl82Fduam3U1@uni-berlin.de...
See
> here:
with
> and
> > working again.
> fix?
> > Brian
Is DVI preferable to VGA?
news:bx1tc.12396$L.2796@news-server.bigpond.net.au...
instructions.
> Brian
cable,
> See
> > here:
> with
we
"screensaver"
> > and
VGA
> > > working again.
> > fix?
> > > Brian
Yes - clearer, crisper, higher quality image.
news:JE1tc.12405$L.11712@news-server.bigpond.net.au...
> instructions.
> > Brian
> cable,
switch.
> > See
> > > here:
along
> > with
> we
> "screensaver"
> > > and
> VGA
> > > > working again.
Dell
> > > fix?
> > > > Brian
Very much so!
> instructions.
> > Brian
> cable,
switch.
> > See
> > > here:
along
> > with
> we
> "screensaver"
> > > and
> VGA
> > > > working again.
Dell
> > > fix?
> > > > Brian
After connecting the white cable we pressed the relevant monitor button and
received a message saying the monitor was in Digital Power Save mode. I
shutdown the computer, pulled out the power cords, pressed both power
buttons, connected up again and it works. Many thanks.
There were no instructions apart from saying how to plug in the cables.
There was a plastic sticker on the screen saying screen resolution is
1280*1024 but the monitor was in 1024*768. Another friend whose computer
arrived last week was in 1024*768 resolution as well. He hasn't tried DVI
yet.
At least it looks good.
Brian
> instructions.
> > Brian
> cable,
switch.
> > See
> > > here:
along
> > with
> we
> "screensaver"
> > > and
> VGA
> > > > working again.
Dell
> > > fix?
> > > > Brian
On Thu, 27 May 2004 06:43:02 GMT, in alt.sys.pc-clone.dell, "Brian K"
Did you check to see if the instructions were on one of the CD-ROMs that
came with the computer? Either a separate CD-ROM just for the monitor, or
on a disk with various drivers, documents, etc.
>yet.
Just a guess: that sticker probably shows the optimum resolution for the
monitor; the actual resolution will be whatever is set up in Windows.
You can change the resolution from the Display applet in Windows Control
Panel.
Nick <mailto:tanstaafl@pobox.com>
Nick's First Law of Computer Virus Complaints:
Just because your computer is acting strangely or one of your programs
doesn't work right, this does NOT mean that your computer has a virus.
Good point. I'll check the CD's.
As far as resolution is concerned, I would have expected Dell to set it to
the optimal monitor resolution. Obviously they don't.
"Nick" <tanstaafl@pobox.com> wrote in message
news😛54bb0l927bdjsvph3vr00si9ff6grf0a4@4ax.com...
> >yet.
> Panel.
news:W5gtc.12955$L.8747@news-server.bigpond.net.au...
and
> yet.
> Brian
IIRC - my Dimension 8300 with the 19" FP came factory defaulted with Windows
generic plug and play monitor. I had to install the 19" FP driver. Can't
remember which CD it was on, but perhaps there was a separate CD for the
monitor, with instructions, etc. The driver would be there.
I like Clear Type.
"snoopy" <snoop-dog@my-doghouse.com> wrote in message
news:A8mdnRstm7leXCjdRVn-uQ@comcast.com...
> The sticker on the LCD was indicating its native resolution (optimal
> resolution). But Windows is where the resolution is set. You should
change
> it to what is indicated on the sticker for best viewing. Might also want
to
> check out Clear Type as well.
> http://www.microsoft.com/typography/cleartype/default.htm?gssnb=1
http://www.microsoft.com/typography/cleartype/cleartypeactivate.htm?gssnb=1
How did you know the driver wasn't installed? (was it Display Properties,
Settings, Advanced, Monitor)
What difference did the driver make?
Windows
> change
> to
Does Clear Type work with a analog connection or DVI (digital) only?
Craig
"Craig" <nospam@nospam.for-me> wrote in message
news:HqItc.1339$Tw.1329@lakeread06...
> > change
want
> > to
> Craig
Sure, don't see why not. Says it also helps CRT displays a little too.
http://www.microsoft.com/typography/WhatIsClearType.mspx
I use it on my CRT monitors.
Brian
> > change
want
> > to
> Craig
In article <HqItc.1339$Tw.1329@lakeread06>, nospam@nospam.for-me says...
> > change
> > to
> Craig
I use clear type on a 21" Sony CRT, where it is supposed to make
"minimal" difference. I can definitely see a difference and I love it.
Louise
