ultrawide monitor question
It will be a problem for some games. Not all games can support a 21:9 ratio. For example all or nearly all cut scenes will be off. Before you buy this monitor you should go look at it. It is quite short. Your 1060 should be ok for that resolution.
ill probably stay clear of the monitor then. I heard that the 1060 works well with 2k is that true?
Your current monitor is around 1.5 inches taller and of course doesn't have the occasional issue with games that any 21:9 would have.
If you're happy with your reply, please select it as the answer so others can find it via search.
so does the gtx 1060 work well with 2k?
It depends on which game and which definition for 2k you want to use. In general it is a very good card and an excellent value. If you want to play 1440p some day you would probably want to replace the video card. But below 2560x1440, it should do great in most games.
k thanks
