UMM, NEED HELP BUILDING SUB $750 GAMING PC
Sungho1997
16
HI, FROM AUSTRALIA SO PARTS ARE MORE EXPENSIVE HERE THAN THE US.
Need help on my sub-$750 gaming rig: PLZ REP, THNX..
CPU: Intel Core i5-2400 1155pin Boxed CPU $182
Motherboard: ASUS P8H61-M-LE-USB3 DDR3 USB3 Intel 1155pin Motherboard $82
RAM: G.Skill Ripjaws X F3-12800CL9D-8GBXL 8G Kit(4Gx2) DDR3 1600 $77
Hard Drive: Seagate 3.5" Barracuda 1TB ST31000524AS SATA3 7200RPM 32MB HDD $55
Graphics: Gigabyte 1GB 6850 PCI-E VGA Car $172
Case: Thermaltake Dokker Tower Case without PSU $62
PSU: Gigabyte ODIN 585Watt Power Supply $63
DVD: Samsung External Slim Size DVD RW $29
Total: $728
ALL IN ALL JUST WANTED TO ASK IF IT WORKS AND PLAYS COD 6 and BLACK OPS AT HIGHEST SETTINGS WITHOUT LAG AND HIGHEST ANTI-ALIASING. THNX ONCE AGAIN
Sungho1997
16
UM quickly changed the specs:
CPU: Intel Core i5-2500K 3.3Ghz 1155pin Boxed CPU $212
Motherboard: ASUS P8P67-LE-V3 DDR3 Intel 1155pin Motherboard $129
RAM: G.Skill Ripjaws-X F3-12800CL9D-4GBXL 4G Kit(2Gx2) DDR3 1600 $44
DVD: Samsung External Slim Size DVD RW $29 on 23/07 ONLY,Limited 1 per customer $35
Total: $772
QwertyMusicMan
203
Just to be safe, you can upgrade your PSU to a 600/650w for $5 more. Also, you can get an internal DVD drive for less. You can also get an AMD Processor for less than an Intel, and it still will perform the same. Try an AMD Phenom II X4 965, and that will be much cheaper, but will perform the same. Then pocket the extra cash or spend it on slightly upgrading your GPU to a GTX 560. :)
