ummm pls help :_:
xmax
55
11
Reinstall your graphics drivers, or update them. If you're using Nvidia. Geforce Experience is a great tool to check if you're up to date.
I noticed the 'Microsoft Basic Render Driver'
This usually means your gfx card isn't even configured yet for use. i.e, you need drivers.
PvPGod_
49
Hmm, could you help me a bit on this?
here are my specs
http://gyazo.com/aae8eb4261ea98502fb29896f350980f
xmax
55
11
Go to the 'Display' tab for me, that's where your gfx card is listed.
PvPGod_
49
http://gyazo.com/1601814334bc67558106f7fa1e576540
xmax
55
11
do you have a graphics card installed on your PC? Right now you're defaulting as if you have none.
If you do, go download the specific drivers for your graphics card.
PvPGod_
49
not really sure, I wasn't the one who set my pc up. I thought I had downloaded the drivers, guess not. Do you have a link for them?
PvPGod_
49
actually, I found where i'm suppose to download them. doing it now, Should I download the chipset drivers aswell?
xmax
55
11
Usually you'd get a CD from the graphics card's manufacturer.
However, trying downloading 'Speccy'. It's a very small tool that shows all advanced information about your PC. And we're looking for your GPU information specifically.
Official download page: http://
EDIT: Was replying while you typed the second response.
And that's great. And yes, download those too.
