Hi,
Firstly here's my current setup
asus H170 Pro gaming motherboard
i5 6600k
Cooler Master 212 evo
My case fans aren't connected to the mobo and have their own fan controller so not fussed about these. The problem i'm having is my CPU cooler is constantly running at around 1600rpm regardless of load.
I've tried to adjust in the Bios, no effect unless I swith it to DC mode but from what i understand this is a legacy setting and best avoided?
Also attempted to use Ai Suite lll to adjust fan but no luck there either, firstly the CPU fan graph is greyed out. Followed instructions from this post http://www.tomshardware.co.uk/answers/id-1717544/asus-fan-xpert-control-cpu-fan-running-max-speed.html#14857554
to adjust settings and this fixes the graph in AI SUite, yet the changes i make still appear to have no effect on the rpm of the cpu fan.
I've updated the BIOS with no observable effect.
When running fan Xpert 3 in AI Suite I'll most of the time get an error part way through the bench marking or fan tuning process saying 'abnormal program termination' then it quits out.
This is currently what I'm seeing in fan Xpert 3
despite what you can see on the graph, the fan is still running at 1600rpm
Mainly wanting to adjust this as my PC currently sounds like a monster and surely it shouldn't be running at almost full speed straight after startup and whilst idling?
i5 6600k
