Unable to format Sandisk Cruzer Blade 32GB USB Flash Drive
thugslife
205
tried all the possible ways like go to drive management and then format tried to format via CMD no result also..
what can I do USB just came out of the box and have the issue nut it was not in warranty
I had a similar major Cruzer problem but I found an easy solution. After trying everything I could, my Cruzer storage data suddenly could not be seen or accessed. Out of frustration I forceably slide the blade back and forth and strongly locked it forward. Then to my surprise everything was normal and worked perfectly. I also had the similar problem with an older camera suddenly not be able to recognize any memory card. I scraped the contacts and worked it back and forth in the camera slot and anchored it in firmly. Result - instantly recognized and no problems.
