quickrabbit5
Hi,
I am unable to load control panel. Everything else on my computer seems to be working fine. Internet, my computer, ect. ect.
But for some reason Control panel wont load. When I click on it, a blank window appears for about 10 seconds, then closes by itself.
I have done multiple spyware and virus scans so I don't think that's a problem.
Any help would be appreciated.
I have had the same thing happen. The control panel was not accessible due to a registry repair progam I ran. This happened twice. On the first occasion, I was able to do a system restore and recovery access to my Control panel. The second time, I had to reinstall the OS.
quickrabbit5
Every time I try a system restore this happens:
The Writer experienced a transient error. If the backup process is retried, the error may not reoccur. (0x800423F3)
Edit: I'm using vista 64 bit.
Sorry for the double post.
Ouch. Have you tried running it in 'safe mode'?
G
Guest
Guest
I have tried to load folders onto a flash drive but the 3 DCIM options options that I had been using are missing from the MY Computer page. Any suggestions for fixing this. Thanks
