Mobo : Asus Maximus VIII Hero
CPU : Intel Core i7 - 6700K ( Max DDR4 frequency supported without XMP is 2400mhz according to intel specs )
Chipset : Z170
Ram : 4 * 8 GB Corsair VENGEANCE RGB PRO DDR4 ( cmw16gx4m2c3200c16 ) // Two modules got Sk chips and other two have Samsung
Simply it won't execute normal boot with cleared CMOS and MemOK function is needed to set timings, MemOK automatically enables XMP and loads 3200MHz XMP profile but DDR frequency must be set on 1600MHz, So each module runs on 800MHz ( dual channel DDR ) and it POSTS anything higher than 1600hmz fails to POST with Q-Code 55
As far as i know 32Gb is supported on the mobo and cpu and there shouldn't be a problem with quad module running in dual channels ??!!
Performance benchmarking shows significant reduction in scores comparing with dual module installed and run at 3200MHz and laggy windows explorer
Info is added by screen shots
Chipset : Z170
