Archived from groups: microsoft.public.win2000.setup_deployment (More info?)
Hello all,
I'm trying to create an unattend CD for multiple computers
where I work, and thus its setup so that the i386 folder
is on the CD image and the user who runs the CD has to
first fdisk it then restart then type "unattend
ComuterName" and it runs a batch file that basically
starts the unattend proccess with the right information
(I'm not familiar with how that whole getup works, the udf
file etc, but thats not where I'm having the trouble)
what happens is the script works fine and starts copying
files over to the harddrive (the windows 2000 setup screen
thats blue)
so what happens is that I keep getting file cannot be
copied on the same files....
files are:
bachsb~1.rmi
beetho~2.rmi
claire~1.rmi
danceo~2.rmi
fureli~1.rmi
hallof~2.rmi
mozart~2.rmi
utopia~1.wav
utopia~2.wav
utopia~3.wav
utopia~4.wav
the problem thats bugging me and what i cannot figure out
is that i create a new image each time and its the same
files over and over...
i use barts boot CD (BCD) to create a boot CD with CD-rom
support... (if you know anythning specifically about bcd i
run bcd cdromsi (http://www.nu2.nu/bootcd/#cdromsi)
I've also re copied the whole i386 directory from our 2000
server CD and slipstreamed it just to see if the problem
was corrupt files from the original transfer...
I've tried different burners and different material and
still nothing...
and as a last resort yesterday, i tried deleting the files
and then editing a few ini files in the i386 directory
(dosnet.ini, layout.ini, and i think one more but i can't
remember the file name)
when i did the above, i was able to get through the blue
screen setup part, but it would give a fatal error when it
actually started windows saying setup logs should contain
more information...
Any help is appreciated,
Christopher Vanderlinden
Hello all,
thats blue)
files are:
bachsb~1.rmi
beetho~2.rmi
claire~1.rmi
danceo~2.rmi
fureli~1.rmi
hallof~2.rmi
mozart~2.rmi
utopia~1.wav
utopia~2.wav
utopia~3.wav
utopia~4.wav
still nothing...
more information...
