Question Unattended W11 no Monitor fails to display certain programs properly in RemotePC
bxdobs
9
Lenovo ThinkStation P3 was delivered with W11 Pro and NVIDIA T400 Video Card ... have set it to bypass login and all seemed fine until installing Malwarebytes ... the MB windows are blank unless I plug in a monitor ... can't seem to ask the right question to find a solution to this dilemma (Migrating a W7 Pro Lenovo machine which works 100%)
PC is acting purely as an automation processor for Email, Security, and data Pre Processing ... runs unattended 24/7/365
Have you considered putting a dummy monitor plug on the host?
Something like this -- https://www.amazon.com/Headless-Display-Emulator-Headless-1920x1080-Generation/dp/B06XT1Z9TF?th=1
in searching some forums have run across this suggestion ... seems simple enough that NVIDIA would/should/could potentially provide some setting(s) that wouldn't require fooling the hardware. ... consider older monitors and or some new monitor that the Video card doesn't recognize ... from my perspective would expect some way to manually set the VIDEO card to some fixed mode.
