Unbelievably low fps with GTX 650 TI and E7500
Mikoloco
319
Im aware my cpu isn't the best one, but i've getting 22 fps on 1280x720p and even if I change to 1920x1080 there is absolutely no difference.
What could be causing?
I have 6 GB RAM, the graphic card is new.
To confirm which causes the issue, you can try running software like MSI Afterburner. Run the game in low settings and try to check the GPU usage, if gpu usage is low then the problem is because of the core 2 duo processor
Could be a problem with GPU then since it is running at 80-100% even in low settings. Check if its getting over heated. Try to clean the GPU and fans in the computer including CPU fan. I guess you will have enough power supply for the PC
