OK to start off with im not a gamer at all and I know this card is overkill for me, but I got it for free when I built the PC. The problem is that its very noisy at the stock settings, so Ive been using ATI tray tool to fool around with the fan speeds and Ive gotten it much quieter. But Id like to know if it would make sense to under clock it to keep it running cooler at the lower fan speeds?? I have the fan set on auto right now with these settings
0 - 10%
55- 25%
60- 35%
65- 75%
70- 100%
It usually stays at around 55c or so under normal pc use, no gaming. What are the safe temps for these cards?? Should I under clock it?? How low can I go??
thanks
Frank
0 - 10%
55- 25%
60- 35%
65- 75%
70- 100%
thanks
Frank
