Undervolted cpu i7-8750h by -0.050 VCoreOffset - Ran prime95 14 hours. Help with results.
Artonn
35
Hi I recently got a new laptop and I wanted to undervolt the cpu to spare my pc from unnecessary heat. I used Intel extreme tuning utility to undervolt the cpu and prime95 version v29.4 build 8 to stress test the cpu.
Now my question is, are my results fine, did I undervolt it too much? For some reason one of my workers has not been stopped, but are not running any tests at all.
Here's a picture:
Here's my results
FATAL ERROR: Rounding was 0.4999716919, expected less than 0.4
Hardware failure detected, consult stress.txt file.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
[Sat Aug 25 00:57:08 2018]
Self-test 12K passed!
[Sat Aug 25 01:02:12 2018]
Self-test 8K passed!
[Sat Aug 25 01:08:39 2018]
Self-test 15K passed!
[Sat Aug 25 01:14:31 2018]
Self-test 10K passed!
[Sat Aug 25 01:21:19 2018]
Self-test 16K passed!
[Sat Aug 25 01:26:48 2018]
[Sat Aug 25 01:31:51 2018]
[Sat Aug 25 01:36:08 2018]
FATAL ERROR: Rounding was 0.4628458633, expected less than 0.4
FATAL ERROR: Rounding was 0.4984615582, expected less than 0.4
[Sat Aug 25 01:46:21 2018]
[Sat Aug 25 01:51:56 2018]
[Sat Aug 25 01:57:13 2018]
[Sat Aug 25 02:03:15 2018]
[Sat Aug 25 02:08:25 2018]
[Sat Aug 25 02:13:27 2018]
[Sat Aug 25 02:19:42 2018]
[Sat Aug 25 02:24:50 2018]
[Sat Aug 25 02:31:42 2018]
[Sat Aug 25 02:38:23 2018]
[Sat Aug 25 02:45:01 2018]
[Sat Aug 25 02:50:15 2018]
[Sat Aug 25 02:56:06 2018]
[Sat Aug 25 03:01:49 2018]
[Sat Aug 25 03:08:16 2018]
[Sat Aug 25 03:13:45 2018]
[Sat Aug 25 03:19:21 2018]
[Sat Aug 25 03:24:42 2018]
[Sat Aug 25 03:30:01 2018]
[Sat Aug 25 03:35:15 2018]
[Sat Aug 25 03:41:58 2018]
[Sat Aug 25 03:48:03 2018]
[Sat Aug 25 03:54:00 2018]
[Sat Aug 25 04:00:50 2018]
[Sat Aug 25 04:06:53 2018]
[Sat Aug 25 04:12:41 2018]
[Sat Aug 25 04:19:44 2018]
[Sat Aug 25 04:25:26 2018]
[Sat Aug 25 04:31:07 2018]
[Sat Aug 25 04:36:19 2018]
[Sat Aug 25 04:41:21 2018]
[Sat Aug 25 04:46:26 2018]
[Sat Aug 25 04:51:56 2018]
[Sat Aug 25 04:57:15 2018]
[Sat Aug 25 05:04:41 2018]
[Sat Aug 25 05:10:23 2018]
[Sat Aug 25 05:17:21 2018]
[Sat Aug 25 05:24:34 2018]
[Sat Aug 25 05:30:41 2018]
[Sat Aug 25 05:36:34 2018]
[Sat Aug 25 05:42:11 2018]
[Sat Aug 25 05:47:46 2018]
[Sat Aug 25 05:54:15 2018]
[Sat Aug 25 05:59:51 2018]
[Sat Aug 25 06:04:56 2018]
[Sat Aug 25 06:11:56 2018]
[Sat Aug 25 06:17:32 2018]
[Sat Aug 25 06:25:57 2018]
[Sat Aug 25 06:31:45 2018]
[Sat Aug 25 06:38:00 2018]
[Sat Aug 25 06:43:36 2018]
[Sat Aug 25 06:48:49 2018]
[Sat Aug 25 06:54:21 2018]
[Sat Aug 25 07:00:04 2018]
[Sat Aug 25 07:06:16 2018]
[Sat Aug 25 07:11:19 2018]
[Sat Aug 25 07:16:26 2018]
[Sat Aug 25 07:21:27 2018]
[Sat Aug 25 07:29:06 2018]
[Sat Aug 25 07:35:19 2018]
[Sat Aug 25 07:40:27 2018]
[Sat Aug 25 07:45:40 2018]
[Sat Aug 25 07:51:18 2018]
[Sat Aug 25 07:57:18 2018]
[Sat Aug 25 08:02:56 2018]
[Sat Aug 25 08:08:13 2018]
[Sat Aug 25 08:14:34 2018]
[Sat Aug 25 08:20:52 2018]
[Sat Aug 25 08:26:52 2018]
[Sat Aug 25 08:32:19 2018]
[Sat Aug 25 08:38:06 2018]
[Sat Aug 25 08:43:24 2018]
[Sat Aug 25 08:48:26 2018]
[Sat Aug 25 08:53:31 2018]
[Sat Aug 25 08:58:46 2018]
[Sat Aug 25 09:03:51 2018]
[Sat Aug 25 09:08:59 2018]
[Sat Aug 25 09:15:06 2018]
[Sat Aug 25 09:20:08 2018]
[Sat Aug 25 09:26:11 2018]
[Sat Aug 25 09:31:26 2018]
[Sat Aug 25 09:36:50 2018]
[Sat Aug 25 09:42:06 2018]
[Sat Aug 25 09:47:36 2018]
[Sat Aug 25 09:52:55 2018]
[Sat Aug 25 09:57:56 2018]
[Sat Aug 25 10:05:48 2018]
[Sat Aug 25 10:11:30 2018]
[Sat Aug 25 10:17:34 2018]
[Sat Aug 25 10:22:37 2018]
[Sat Aug 25 10:28:12 2018]
[Sat Aug 25 10:33:29 2018]
[Sat Aug 25 10:38:38 2018]
[Sat Aug 25 10:43:57 2018]
[Sat Aug 25 10:49:05 2018]
[Sat Aug 25 10:55:28 2018]
[Sat Aug 25 11:00:52 2018]
[Sat Aug 25 11:06:41 2018]
[Sat Aug 25 11:11:58 2018]
[Sat Aug 25 11:17:05 2018]
[Sat Aug 25 11:22:14 2018]
[Sat Aug 25 11:27:18 2018]
[Sat Aug 25 11:32:34 2018]
[Sat Aug 25 11:37:48 2018]
[Sat Aug 25 11:42:59 2018]
[Sat Aug 25 11:48:22 2018]
[Sat Aug 25 11:53:26 2018]
[Sat Aug 25 12:01:14 2018]
[Sat Aug 25 12:06:34 2018]
[Sat Aug 25 12:12:49 2018]
[Sat Aug 25 12:18:15 2018]
[Sat Aug 25 12:23:34 2018]
[Sat Aug 25 12:28:49 2018]
[Sat Aug 25 12:34:15 2018]
[Sat Aug 25 12:39:36 2018]
[Sat Aug 25 12:44:38 2018]
[Sat Aug 25 12:50:36 2018]
[Sat Aug 25 12:55:42 2018]
[Sat Aug 25 13:02:32 2018]
[Sat Aug 25 13:09:10 2018]
[Sat Aug 25 13:14:15 2018]
[Sat Aug 25 13:20:35 2018]
[Sat Aug 25 13:26:17 2018]
[Sat Aug 25 13:31:44 2018]
[Sat Aug 25 13:36:55 2018]
[Sat Aug 25 13:43:08 2018]
[Sat Aug 25 13:48:25 2018]
[Sat Aug 25 13:53:30 2018]
[Sat Aug 25 13:59:23 2018]
[Sat Aug 25 14:04:32 2018]
[Sat Aug 25 14:11:08 2018]
[Sat Aug 25 14:16:15 2018]
[Sat Aug 25 14:21:25 2018]
[Sat Aug 25 14:26:45 2018]
[Sat Aug 25 14:32:04 2018]
[Sat Aug 25 14:37:55 2018]
[Sat Aug 25 14:43:06 2018]
[Sat Aug 25 14:48:42 2018]
[Sat Aug 25 14:54:55 2018]
[Sat Aug 25 15:07:12 2018]
[Sat Aug 25 15:12:40 2018]
[Sat Aug 25 15:18:38 2018]
[Sat Aug 25 15:24:00 2018]
[Sat Aug 25 15:29:03 2018]
Please don't supply that long a set of results outside of a spoiler quote.
I think you know the answer. The CPU can no longer reliably do maths. Everything your PC does is ultimately maths.
Laptop CPU's are often heavily binned for running at low voltages, there just may not be the room to reduce it further.
Hi @13thmonkey. I'll use a spoiler next time. :) Alright I went 0.005+ on the volt and every worker has been running fine for 5 hours now. I guess this is my limit. :) It's strange tho, I've read that people with the same laptop has decreased their voltage to 0.120-. while my minimum voltage only can go to 0.045- My laptop is a asus zephyrus m
