Uneven LED backlight
How much is considered normal?
I'm using a VG278H and over the last two weeks or so have noticed a couple of things. A coin sized dark spot in the top right corner, streaks of dark/light patches at the bottom of the screen, and a 3 inch wide bar stretching horizontally across the whole screen.
The effects aren't massively noticeable but exist. If I go into a game and pan from side to side I can see them.
Is this normal? It wasn't like this when I bought it (5 months ago)
Thanks.
D
That is an expensive 1920 x 1080 monitor. If I paid that much for one I would not accept any flaws like that. After 5 months of use I'm not sure it will be covered by the warranty though.
