I have two Asus Strix GTX 780 6GBs set up in SLI. For the past week or so, the main card (connected to the display) will randomly and intermittently increase its fan speed (often by a lot), for no apparent reason.
I have found:
1) MSI Afterburner and CPUID HWMonitor both show the fans at 0% when this happens. I had to verify by sight that it was the GPU fans.
2) Temps are always idle-level when this happens, i.e. 27-35 degrees.
3) If I engage the GPU (by firing up a game or a Redshift render), the behavior reverts to normal - the fans appear to follow the profile I set in Afterburner, and then (temporarily) go back to 0% once the cards cool down.
4) I haven't identified any unusual processes running when this happens. The only thing that's consistently active is svchost.exe. I suppose that could be infected, but MBAM and Trend Micro Housecall turned up nothing.
5) I'm using the latest drivers (375.70) on Win 7 64-bit. No Geforce Experience.
Has anyone seen this behavior before? Does anyone know what it might be?
I have found:
